1. AC Question's Avatar
    I recently got the S4. Right out of the box I was having issues with it dropping my wifi network, regardless of what network/strength of the network. I have the "smart network switch" and "keep wifi on during sleep" settings set to prevent this, but was still having problems.
    I sent it in to Samsung for possible repairs and they found nothing wrong with it. I recently found the solution - I had to access the service mode and turn the "Wifi Power Save" mode off. Since then I have had no problems with it dropping my wifi network. But I have been experiencing more battery drain than I would like. Even with it remaining idle it seems to eat through battery. I can get about 12 hours out of it, but that's with only a little use. Any more would be pushing it.
    Just curious if anyone has a different work around for my wifi problem, given the solution that I have found in turning the wifi power saver mode off...
    Thanks
    06-12-2015 06:25 AM
  1. Replies: 20
    Last Post: 10-27-2016, 09:43 AM
  2. Battery life terrible on nexus 5 running 5.1.1CM
    By goutham kumar muvva in forum Google Nexus 5
    Last Post: 06-12-2015, 09:59 AM
  3. how to unlock my galaxy S4 to use on straight talk
    By simpsonj60 in forum Samsung Galaxy S4
    Last Post: 06-12-2015, 05:13 AM
  4. Question of LG Battery & SD Promotion
    By netjack in forum LG G4
    Last Post: 06-12-2015, 05:01 AM
  5. is it worth a new battery?
    By aldo82 in forum Google Nexus 5
    Last Post: 06-12-2015, 04:38 AM
