1. AC Question's Avatar
    iam using Samsung Galaxy S4 and i want to move my download apps from internal memory to SD card memory because my RAM is about to be full and my SD memory card is more than half empty help!
    06-22-2015 01:54 AM
  2. itguyjax8430's Avatar
    Welcome to Android Central!
    Try going to settings, application manager, all apps, find the apps you want to move and see if there is an option to move them. If there is not they only other way you can move them is to be rooted.
    06-24-2015 11:52 AM
  1. Replies: 46
    Last Post: 11-19-2015, 05:59 PM
  2. Replies: 3
    Last Post: 06-26-2015, 05:22 PM
  3. Replies: 3
    Last Post: 06-26-2015, 06:47 AM
  4. How Can I disable the fingerprint lock out?
    Last Post: 06-24-2015, 11:43 AM
  5. Replies: 1
    Last Post: 06-24-2015, 11:40 AM
