1. AC Question's Avatar
    My phone has been working well, but yesterday it developed a serious problem. The phone overheats to the point where it is painful to hold, and will not start. I tried a different, fully charged battery, and when that didn't work, I put it in a container of rice, since my location is very humid and the humidity might have worked its way in. After 30 minutes, I took the phone out and it was extremely hot. I removed the battery and let it sit in rice overnight, but I still cannot get it to even power on.
    07-07-2015 07:44 AM
  2. maduro78's Avatar
    It sounds like your using an aftermarket charger or one not rated for your phone
    sent from my LG G4 vs986
    07-07-2015 08:19 AM
  3. Rosparr's Avatar
    Actually, everything I have has a Samsung logo. And the battery I used came directly from a Samsung charger, and works in another S4 very well
    07-07-2015 08:37 AM
  4. belodion's Avatar
    If there is moisture inside your phone, I think it would need much more than overnight to get it out using the rice method.
    07-07-2015 08:41 AM
  1. Sanctuary cities back in the news.
    By Mooncatt in forum Politics
    Last Post: 07-07-2015, 08:28 PM
  2. How is Android App data accessed by other apps?
    Last Post: 07-07-2015, 09:51 AM
  3. Galaxy S5 wont charge via wall but charges through PC
    By Drexel Wright in forum Samsung Galaxy S5
    Last Post: 07-07-2015, 07:44 AM
  4. Why is my phone cutting on and off?
  5. Replies: 0
    Last Post: 07-07-2015, 07:07 AM
