1. Preston matope1's Avatar
    I have owned this phone for about 3 months and I have had awesome battery life until recently....about a month after I updated to lollipop. I bought a new battery hoping it was the battery causing the drain. I have tried everything from clearing the cache to wiping the device and still no change. Is there any assistance I can further get? Screenshots of my battery usage are attached
    Attached Thumbnails My Gs4 drains battery way too fast-screenshot_2015-07-20-10-59-08.jpg
    07-20-2015 03:59 AM
  2. Hassan272's Avatar
    It's an issue with Android Lollipop causing your battery drain. When my S4 was on Lollipop, I'd average 11.5 hours battery life with 3.5 hours of SOT. I downgraded to Kitkat and am now getting 14 hours battery life with 4.5-5.5 hours SOT. If you don't like the idea of downgrading your OS, you could try:
    1. Use auto-brightness,
    2. Disable Wifi/Mobile data when not in use or on standby,
    3. Keep power saving on,
    4. Disable Wifi scanning,
    5. Disable Sync and unnecessary apps and services.
    07-21-2015 04:10 PM
  3. Preston matope1's Avatar
    Thanks
    However i wanted to ask if it is possible to load an alternative Rom like that situation of the S4 LTE-A version that got a custom Rom for the Note 4. I read comments from users saying their Ram management got way better
    07-27-2015 02:08 AM
  1. How can I reset my phone without it restoring data?
    Last Post: 07-20-2015, 08:29 AM
  2. Is my Samsung Galaxy S4 Mini dead or is it my battery?
    Last Post: 07-20-2015, 05:12 AM
  3. Why is my phone asking for the private password after changing the line?
    Last Post: 07-20-2015, 04:34 AM
  4. Replies: 0
    Last Post: 07-20-2015, 01:59 AM
  5. Replies: 0
    Last Post: 07-20-2015, 01:48 AM
