1. Mike Pawka's Avatar
    Is there a way to disable the power on button on the top right side? I would like to still use it for power off but disable power on or at least set the time delay to a higher value. I keep accidentally turning the device on when putting it in my pocket. The button is not needed for power on as far as I can tell, the home button can be used for that.
    Mike
    07-28-2015 10:47 PM
  2. Mike Pawka's Avatar
    After thinking about, it wouldn't need to be disabled, just have a delay like when the phone is first turned on, so you can't accidentally turn it on.
    07-30-2015 08:12 AM
  1. Can I move music from Google Play to Play Music on my Galaxy S6?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 11-05-2016, 10:43 AM
  2. droid MAXX front button not working.
    By droiduser247 in forum Ask a Question
    Last Post: 08-05-2015, 10:33 AM
  3. Why won't Google Play Services install on my Samsung Tablet?
    Last Post: 07-31-2015, 07:59 AM
  4. Background data on WiFi
    By calbrs04 in forum Sony Xperia Z3
    Last Post: 07-29-2015, 09:23 AM
  5. Replies: 1
    Last Post: 07-28-2015, 09:28 PM
