1. ErikGBL's Avatar
    I broke the LCD display on my Galaxy S4. I replaced it and the phone comes on OK now, but it comes only to the screen where you are supposed to dial in a PIN code. My SIM card does not have a PIN code, thought. I can only perform emergency calls. The operator company name is displaced on the screen so it actually recognizes that the SIM card is present. The phone also receives SMS messages but I can not read them because it prompts me for a PIN code. How shall i proceed?
    08-06-2015 07:00 AM
  2. hallux's Avatar
    That PIN isn't for the SIM card, that PIN is security on the phone. You never set up a PIN to unlock the device?
    08-06-2015 07:31 AM
  3. ErikGBL's Avatar
    No, or else I have forgotten it. Is it anyway to bypass it? Is this also a four digit pin code? Is there anyway to reset the password without performing a full factory reset? I assume it came without any lock?
    08-06-2015 12:13 PM
  4. extraclass's Avatar
    Some carriers can unlock your phone. Contact them first!
    08-07-2015 12:00 AM
  1. How much is the apps consuming from my phone storage?
    Last Post: 10-12-2015, 12:40 AM
  2. How much storage the apps are consuming?
    By nirmalyadhar in forum General Help and How To
    Last Post: 08-06-2015, 07:27 AM
  3. Replies: 1
    Last Post: 08-06-2015, 07:04 AM
  4. Phone just stopped working propertly.
    By Rodrigos GamerVids in forum LG G3
    Last Post: 08-06-2015, 06:56 AM
  5. Help! My 0+ 360 Camera built in app is missing!
    Last Post: 08-06-2015, 06:07 AM
