Greetings to you all,
So my issue is similar to many threads I've read on the internet whilst I've owned what has turned out to be a nightmare: S4.
I bought my S4 around 2 years ago, over that time I've replaced the charger port around 7 times.. I am a heavy user and do charge daily, many times twice. (The battery of the S4 being pathetic is another topic for another day)
So you wonder, 'ok what can be the problem? this guy replaced the port and they are cheap on eBay so what gives?'
Let's begin.
1. Problem as usual, red light top right hand corner of the phone and so the charge symbol on the battery has stopped displaying, so I think 'ok, perhaps this time the battery really has give up.' Nope
2. Replaced battery with 2 different spares to check if battery problem. Nope
3. I keep spare charging ports because yea, it comes with the territory of owning a/my S4 at least. So I replace the charging port not once but twice because the problem persisted. Each time I get around 10% on to the standard battery as normal, then once more the red light starts flashing. So has this work? Nope.
I'm now left with 2 options which is to see if someone can suggest another part to replace or to sell it on eBay for spares/repairs.
Every thread I look at has the simple solution, just replace the charger port and carry on. So what do you try when not even that solves the problem?
Many thanks for reading the thread and have a wonderful day.
- eXp0
PS. (Couple of questions I'll answer to avoid people wasting their time)
Have you tried connecting the phone to your computer via USB?
Yes I have, it does connect and I can transfer data but the phone gains no charge from being connected.
Have you tried using a different plug head and USB cable to charge?
Yes and Yes, the phone has even been testing taking a charge from a battery pack over electrical plug but no luck.
Let's begin.
- eXp0
