1. AC Question's Avatar
    My samsung s4 has a broken lcd. Im trying to figure out if its only the lcd or the phone is not able to receive calls. Im trying to charge it, How do i know if the phone is on or off. What color should i see on the lcd light if its on.
    09-10-2015 06:14 PM
  2. Rukbat's Avatar
    If the LCD is bad, almost anything from total white to total black, depending on what's bad.
    If you want to know if it receives calls, leave it on the charger overnight, then call it. If it rings, it receives calls.
    09-10-2015 06:34 PM
  1. Replies: 4
    Last Post: 09-22-2015, 02:02 PM
  2. On the Edge plan.can I use my Droid Turbo?
    By AC Question in forum Motorola Droid Turbo
    Last Post: 09-11-2015, 11:02 AM
  3. Replies: 2
    Last Post: 09-11-2015, 05:48 AM
  4. Replies: 0
    Last Post: 09-10-2015, 05:56 PM
  5. Samsung S4 Gmail Stuck on Sync, What Should I Do?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 09-10-2015, 05:55 PM
