My Samsung Galaxy S4 i9505 switches off immediately when pressure is applied to motherboard, whilst it is in frame. For example if i tighten the four screws on the top of the mid frame, it will immediately switch off. I have put a piece of paper under motherboard to stop it cutting out when it is pressed down, this works but, if i put in top 4 screws on mid frame it will not start? Also on Bezel, by volume down sound button their is a slight gap, where mid frame bezel will not close on front frame properly. Can anyone explain it please.
