Elmojo
Well it would apear that as warthog55 has already posted that it is in fact the Display Assembly that has been damaged. I have never come across anything like this before. I have well over 28 years as a Firmware Engineer and this is a first.
As most of you on here have posted I did the automatic firmware upgrade after which the soft keys stopped working. It was not dropped or exposed to any fluids during or after the upgrade. So that only leaves the actual firmware or the upgrade process. I obviously don't have the schematics to work out what could have happened. At a wild guess I would look for something voltage related to these keys. If the voltage to these keys is programmable from the firmware. I have the Snapdragon 600 version as most European S4s will do. As the problem for me was just the soft keys it would be the most likely place to start. As I posted above my phone is now working perfectly after Samsung replaced the Display Assembly. I did read somewhere that someone had gone back in versions of firmware and that they got the keys to work again. How reliable that post was I don't know.
I hope this help in some way for those of you still trying to fix the problem.
