I normally go with Anker or Hyperion, and I see a few different Anker packages for the S4.
You can use as large a capacity battery as you like (you are when you plug the phone into a car charger - that's about a 30,000mAh battery), but most of them are thicker, so they need a new back (which comes with the battery) and make the phone thicker.
Unless you need more capacity than you get between being able to charge, there's nothing to gain by using a larger battery. (If the battery gets down to 40% by 2 in the afternoon, and you're in the office, just plug in the charger until you go home.)
If you don't let the battery drop below 40%, it should last long enough that the phone will be worthless. (I'm still using the original battery in my 11 year old Motorola V551.)
