how to restart with no power button, no root, and no computer?
I have quite a pickle.
I work on a campus with spotty cell coverage, especially inside of larger buildings. I get the X next to the signal strength meter. Problem #1 is that ever since the Android 5.0 upgrade if my phone has no coverage for more than a few minutes it will just give up and not reconnect until I restart. Anyone know what to do about this? If so please tell me and forget the rest of this post. I've tried airplane mode on and off and changing the network type from Global to CDMA to GSM and back. No joy.
I've been working around this problem for months with daily restarts.
Problem #2 is my power button died. I can start up using a USB connection on a computer and I can restart using an adb command, again from a computer. This wasn't a satisfactory workaround since I'm not always near a computer when I need to use my phone.
I tried to find a way to use an alternate button as the power button or use an app to trigger a restart but everything I found requires root.
From my adventures across the interwebs there's no known way to root a Verizon S4. I tried a couple methods which didn't work. My options on what to attempt are also limited because I can't attempt any that require the power button.
I bought some replacement switches off of ebay and tried to solder a replacement. Personally I don't know how anyone could replace such a switch. The contacts are surface mount which is annoying enough but the switch contacts are literally a fraction of a millimeter away from the switch casing and if you get solder on the contact and the casing you've shorted to ground and you're hosed.
Anyway, I failed to replace the switch and I'm pretty sure I've damaged the surface contacts in the process. I can't get the solder to stick at all. So power button isn't going to happen.
So, my questions are:
Any ideas on my reception issue?
Anyone know how to start / restart an S4 without a computer?
Anyone know how to root a Verizon S4?
Anyone know how to install an app that will restart an S4 without root?
