1. Natashadawn's Avatar
    Tried clearing cache and rebooted... still glitches random pink white or black square. Tried factory reset twice... still same reboot with messages. Unfortunately touchwiz has stopped or. Random camera or some other app
    11-02-2015 08:17 AM
  2. Golfdriver97's Avatar
    Welcome to the forums. You might have to have the stock ROM reflashed. Do you have a Best Buy with a Samsung center near you?
    Natashadawn likes this.
    11-02-2015 08:37 AM
  3. Natashadawn's Avatar
    11-02-2015 08:42 AM
  4. Natashadawn's Avatar
    I'm sure I can find one.. best buy...what is stock rom reflash?
    11-02-2015 08:45 AM
  5. Golfdriver97's Avatar
    It is reinstalling Android on your phone. If this is a software error, the reinstall should fix it.
    11-02-2015 09:02 AM
  6. Natashadawn's Avatar
    OK thank you... any idea as to why it started to bootloop? So I don't make the same mistake twice... me and my spouse have identical s4... his has had no issues but mine have been endless or so it seems
    11-02-2015 09:10 AM
  7. Golfdriver97's Avatar
    The bad part is it could have been anything. The old saying of sometimes you get the bear, and sometimes the bear gets you; I tally this to the bear gets you.
    11-02-2015 09:56 AM
  8. Natashadawn's Avatar
    Can I do the stock ROM reflash from my phone... I see some other posts that hint at getting it done online... bit my phone is still rebooting itself I want to get it to stop to try DIY it....
    11-02-2015 10:22 AM
  9. Golfdriver97's Avatar
    You can try. I would look at a lot of youtube videos on how to do it. Also, we have a couple guides here: http://forums.androidcentral.com/amb...ml#post4641895
    The only thing i would have to say is, if you have any questions about any kind of step, ask before doing anything. Flashing a ROM for the incorrect device, or even the correct device, but wrong carrier can render the device useless.
    As for stopping the boot loop. Try pulling the battery for a few minutes.
    11-02-2015 10:26 AM
  10. Natashadawn's Avatar
    I tried that few times even over night it works for few minutes then the "unfortunately" messages start popping up
    11-02-2015 10:58 AM
  11. Golfdriver97's Avatar
    OK...aside from flashing the new ROM I am not sure what else to suggest. Are you going to try to do it yourself?
    11-02-2015 02:21 PM
  12. Kelly Kearns's Avatar
    Did you get a new update for your phone right before this started?
    11-02-2015 02:25 PM
  13. Natashadawn's Avatar
    I haven't tried it yet but I found someone a blog about stopping or disabling glance view mk on my application manager and rebooting it stopped the boot loop sort of then I had to disable automatic updates on Google play because it started shutting off because too many apps at once and I updated singularly and it now only glitches and shut off once today so I'm close now I think I may have a virus but I'm still researching... started reading Another thread on here but I can't add the link?
    11-04-2015 05:52 PM
  14. Natashadawn's Avatar
    Also... I noticed after the updates that the square glitches popping up in the background everywhere on my screen were like the air gesture, and or air view so I turned them on and now those squares stopped popping up
    11-04-2015 06:30 PM
  1. Replies: 1
    Last Post: 11-02-2015, 12:32 PM
  2. Replies: 1
    Last Post: 11-02-2015, 11:46 AM
  3. How do I set up group contacts on my Turbo 2?
    By AC Question in forum Motorola Droid Turbo 2
    Last Post: 11-02-2015, 08:37 AM
  4. Replies: 1
    Last Post: 11-02-2015, 08:11 AM
  5. Replies: 1
    Last Post: 11-02-2015, 06:54 AM
