1. david61983's Avatar
    What's the best replacement battery for S4? I see Anker, Ravpower, Zerolemon, and Powerbear on Amazon. There's also the Samsung ones but I'm weary of getting a knock off.
    12-28-2015 08:41 PM
  2. fingertrick's Avatar
    You will get a knock off even when amazon is the seller themselves. I have taken video and hundreds of pictures and settled with them having Samsung overnight it and pay for the actual huge help i was to somehow get them to halt all s4 batteries for a time... i have pictures to display how crafty these fakes are.. Because if you're not looking for it, you won't notice.. until your batteries etc stop working.. I will guide you to my amazon review (if you want to get the brand name) or it may hold a number one review spot still if you go that route. I'm sorry but it's my firm belief due to prior second hand batteries wit phones that the brand was just in the end worth it despite the cost because of the problems. I'm sorry I can't speak to other alternatives for s4 but I hope this helps you man
    12-28-2015 08:54 PM
  3. visheshkhanna's Avatar
    Absolutely Samsung Galaxy S4 has best battery among all and offers fantastic features to all of its users across the world. To know more features of this smartphone visit samsung website
    12-29-2015 01:43 AM
  4. FiveOverEight's Avatar
    I used an Anker one on my old S4. Worked a treat.
    12-29-2015 02:44 AM
  5. david61983's Avatar
    Well Zero Lemon has a 3000 mah that's the same size as the original going for $9.99. It gets good reviews.
    12-29-2015 06:25 AM
  6. Certi Vee Jones's Avatar
    Do you have the link for this battery via amazon
    01-03-2016 08:14 PM
  7. extraclass's Avatar
    01-04-2016 09:34 AM
  8. Certi Vee Jones's Avatar
    I've had a look at the one you've suggested but it come up with two white ones or the single one which is 7800 mah
    01-04-2016 12:42 PM
  9. Certi Vee Jones's Avatar
    Was looking at this battery would anyone recommend it
    01-04-2016 12:51 PM
  10. david61983's Avatar
    Ordered the Anker battery. Do I need to give it several full discharges like it sats?
    01-06-2016 04:54 PM
  11. extraclass's Avatar
    Put it in and use it! It will take longer to charge but will be fully charged overnight!
    01-06-2016 07:05 PM
  12. david61983's Avatar
    It says to give it several full discharges but some reviews on Amazon say not to.
    01-06-2016 08:40 PM
  13. extraclass's Avatar
    Lots of bad information out there about batteries and charging them. The phone has a charge controller built in that takes care of your battery for you! Install it, charge it and the phone will take care of the rest! If the battery gets too hot it will cut off! When the battery gets charged to 100% it will stop charging , If the battery gets too low, it will cut off!
    01-12-2016 10:05 AM
  14. david61983's Avatar
    Ok thanks. I'm lucky to make it through the afternoon without the phone dying. That's about 1 hr of SOT. Is something wrong? So far it's been worse than my Moto X.
    01-13-2016 08:48 PM
  1. Battery discharging while tablet plugged in
    By cb2367 in forum SHIELD Tablet
    Last Post: 01-27-2016, 01:58 PM
  2. Replies: 1
    Last Post: 12-30-2015, 08:27 PM
  3. Can I move an alarm tone for use on another device?
    By C1tyG1rl in forum Samsung Galaxy S3 Mini
    Last Post: 12-29-2015, 03:42 AM
  4. On my Samsung S4, how to I create and send a group text?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 12-28-2015, 05:56 PM
