1. fadi ayoub1's Avatar
    My phone turns off at 30% or less.
    I bought a new battery and still does the same thing.
    What should i do?
    01-04-2016 09:28 AM
  2. srkmagnus's Avatar
    When you say less how low does it go (percentage)? Also, are you doing anything in particular when it shuts off (e.g. playing games, watching youtube)?
    01-04-2016 09:38 AM
  3. fadi ayoub1's Avatar
    The lowest i got was 15%
    When it turns off usually i'm using social media apps
    01-04-2016 10:13 AM
  4. srkmagnus's Avatar
    And the batter you purchased was new? I think this to be a battery issue. But to be sure, perform a factory reset (backup apps and data first).
    01-04-2016 01:50 PM
  5. fadi ayoub1's Avatar
    I did factory reset it, it's still turning off!!
    01-06-2016 08:41 AM
  6. extraclass's Avatar
    I found out my antivirus app AVG had some kind of battery monitor app built in and was turning my phone off at 30%. I deleted AVG! Solved the problem.
    01-06-2016 07:10 PM
  1. Nexus 5x Battery Life
    By NeilWhitear in forum Nexus 5X
    Last Post: 01-05-2016, 05:49 AM
  2. best aftermarket battery for galaxy s2x/sgh-t989
    By Steve Adams in forum More Samsung Phones
    Last Post: 01-04-2016, 05:09 AM
  3. My s4 keeps on restarting if the battery has gone down to 50%
    By tototinasam in forum Ask a Question
    Last Post: 01-04-2016, 04:50 AM
