1. EmDubya's Avatar
    Hi all. I've recently fitted a TP-Link wifi extender in my home and set it to have the same SSID as my wifi router so that I can have a strong signal around the house without having switch networks. In most of my house there is a signal from both the router and the extender, one weak the other strong. My Samsung Galaxy S4 Mini seems to hunt between the 2 - if I call up the wifi settings it alternates between strong and weak signal for the same network name as it switches from the extender to the router.
    If I set the SSID for the extender different to the router then I can select which to connect to and it stays connected to that, but when I move to another part of the house it obviously stays connected to whichever I have chosen even if that's very weak and the other is strong.
    Is there a way to stop it alternating between a router and a wifi extender with the same SSID and just stick with the stronger signal of the two?
    Thanks
    05-05-2016 08:13 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! What's the model number of the wi-fi extender? Check the manual--does it have the ability to switch between being an extender and an access point?
    05-05-2016 02:44 PM
  3. Rukbat's Avatar
    Another possibility is the placement of the router and extender - there should NEVER be an area where the 2 signals are within 6db of each other. I prefer to keep them to 20db difference (no phone will connect to a wifi signal it can't hear). Wi-Fi Analytics Tool will tell you which signal has what strength wherever you hold the phone.
    05-06-2016 11:23 PM
  4. Runa99's Avatar
    Hi, I have a similar problem with my s7edge where it wont automatically connect to the stronger signal/ nearest router.
    Having used iphones for years previous to jumping ship, i have never encountered this problem iphone just switches automatically.
    How can i fix this problem its getting annoying to constantly disconnect tan reconnect to the nearest router/extender.
    05-23-2016 11:15 AM
  1. Replies: 2
    Last Post: 05-05-2016, 10:50 PM
  2. Replies: 1
    Last Post: 05-05-2016, 02:49 PM
  3. Why does my phone dismiss calls from private numbers?
    By AC Question in forum HTC One M8
    Last Post: 05-05-2016, 12:43 PM
  4. Why am I unable to connect wifi to my mobile?
    Last Post: 05-05-2016, 08:29 AM
  5. Is a phone reset harmful for my phone?
    By Roger David in forum Moto G
    Last Post: 05-05-2016, 04:18 AM
