1. MGV1967's Avatar
    Hello,
    My Galaxy s4 has problems after a update 5.0.1. Wifi and bluetooth doesn't work anymore. I already tried wipe cache, factory reset etc. etc.
    My data bundle consumed after 3 days.
    BUT my biggest problem is:
    I can't use my hearing aids programs anymore and that is a big problem on work!!!
    Those works by bluetooth.
    Android or anyone can help me plse?????
    05-12-2016 12:18 PM
  2. B. Diddy's Avatar
    When you say wi-fi and Bluetooth aren't working, do you mean they can't even switch on, or they switch on but nothing connects?
    Was this an official over-the-air system update (or done via Samsung Kies or Smart Switch), or did you manually download the firmware and install it yourself?
    05-12-2016 04:18 PM
  3. MGV1967's Avatar
    Haai :-)
    Thanks for your comments and apologize for my bad englisch :-)
    Sometimes they can't switch on and sometimes they switch on and off and nothing connects
    It sounds strange, but it seems that I have to start bluetooth first and after that I can start wifi.
    The battery must be above 65% loaded it seems.
    If Bluetooth and wifi starts up they seems to week to work.
    Both wifi and bluetooth are going on and off constantly.
    I turned off the "fast network change" in the wifi settings and the "Passpoint" link.
    In safe mode I deleted some app's en GN resound Smart to.
    I cleaned up by the "wipe cache" methode.
    I had a factory reset.
    I updated my router and I tried 2,4G and 5G
    I did this before but did it again.
    Yes, this was a official update. Not by Kies and not by Smart Switch (?). My phone did the update over home wifi.
    Example:
    I use "gn resound Smart app." programs for my hearing aids.
    Bluetooth starts up (in the evening and with a full battery!!)
    But it can't make a connection with my hearing aids app.
    It can find and make a connection with the phone of a son.
    But even than bluetooth connect en disconnect.
    Thanks already!
    05-13-2016 03:25 PM
  1. Anyone else receive OTA update for the AT&T Samsung Galaxy S7 Edge?
    By Mikedroid713 in forum Samsung Galaxy S7 edge
    Last Post: 06-08-2016, 09:57 AM
  2. Replies: 2
    Last Post: 05-12-2016, 04:57 PM
  3. Data connectivity issue on Marshmallow update
    Last Post: 05-12-2016, 03:40 PM
  4. Replies: 1
    Last Post: 05-12-2016, 02:53 PM
  5. Marshmallow update for Sony Android televisions?
    Last Post: 05-12-2016, 11:33 AM
