1. S V REDDY's Avatar
    Strangest fault, can't enable Wi-Fi, Wi-Fi Hotspot or Bluetooth... When I pull down the screen from the top to bring up the quick select enable menu Wi-Fi will not turn on, it is preselected and a very light green colour instead of a grey for disabled or bright green when it is enabled... Holding the Wi-Fi button down and entering the option doesn't help either as it says "turning on" but does nothing... the toggle switch to turn Wi-Fi on also does nothing.
    07-07-2016 04:11 AM
  2. anon(632115)'s Avatar
    Check out this thread http://forums.androidcentral.com/sam...ble-wi-fi.html
    It could be as simple as a battery pull or as bad as a new motherboard. There's a few things to try.
    Hope you get it working
    07-07-2016 05:15 AM
  1. I cannot seem to update any apps on my very old Nexus one
    By Lynndyloo33 in forum Google / HTC Nexus One
    Last Post: 07-08-2016, 02:08 PM
  2. Replies: 0
    Last Post: 07-07-2016, 03:46 AM
  3. i cannot access my mobile phone
    Last Post: 07-07-2016, 03:30 AM
  4. Computer not showing phone details
    Last Post: 07-07-2016, 03:23 AM
