1. catwoman999's Avatar
    The wifi on my Samsung Galaxy S4 is not turning on!
    In the settings it shows that wifi is turning on but it didn't turn on, also in the notifacation box it doesn't turn on.
    What I should do?
    Can any one help me?
    Thanks!!
    07-24-2016 06:45 AM
  2. sydneycooper1979's Avatar
    Hello! You may need to reset your router and reboot your device.
    Laura Knotek likes this.
    07-24-2016 11:32 AM
  3. catwoman999's Avatar
    Hello!
    But the other devices in the house are connected to the same router and there is no problem, so I think that the problem from the phone!
    Right?
    Any way .. THANK YOU !
    07-24-2016 12:18 PM
  4. sydneycooper1979's Avatar
    Not necessarily. The more devices on your router, the more it gets bogged down. I would suggest resetting your router. And on your phone you can also try clearing your cache partition. If none of that works, a factory reset can be done on your phone, which hopefully will work for you if nothing else does. I hope one of these works for you!
    07-24-2016 05:04 PM
  5. catwoman999's Avatar
    Actually it's my brother's phone. I have Samsung Galaxy S5 and there was a problem, it restarts itself so many times...
    I did wipe cache partition for my phone and it works!!
    So I told him to do it but the problem didn't solved..
    I will tell him to do the factory reset :-)
    THANKS AGAIN :-)
    07-24-2016 05:44 PM
  6. sydneycooper1979's Avatar
    No problem! I hope it works for him!
    07-24-2016 06:59 PM
  7. BlackDemon XXL's Avatar
    This happens with my phone all the time. Don't worry there is a solution to this. The reason why my phone wouldn't connect with Wi-Fi is because the date and time was wrong. If you fix the date and time, it might work. Tell me if this works
    07-25-2016 02:42 PM
  1. Brand new Samsung Galaxy S7 Duos hangs/freezes in standby
    By smaks phone in forum Samsung Galaxy S7
    Last Post: 07-27-2016, 02:18 PM
  2. s4 sound question
    By Decko Romantika in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 07-24-2016, 01:57 PM
  3. Replies: 1
    Last Post: 07-24-2016, 06:24 AM
  4. why my lenovo tab 2 is stocking on systeme recovery ?
    Last Post: 07-24-2016, 05:05 AM
  5. Replies: 0
    Last Post: 07-24-2016, 04:58 AM
