1. shaidaz's Avatar
    I have an old AT&T S4 SGH-i337 that I'm no longer using that I'd like to use for a medical device (Nightscout for Dexcom continuous glucose monitor, if anyone is interested) BUT I need the phone software to be updated to Lollipop.
    I took out my SD card since it had pictures on it and then reset the phone. When I turned it back on and go to "About device" it lists the Android version as 4.4.4 and when I click Software update, it just tells me the software is up to date and it won't let me check for updates for another 24 hrs.
    Anyone know a (easy) fix to this? I'd like to get this software set up so I can use it for my son's CGM.
    I'm on a Mac and I've never synced the phone up to my computer, if that makes any difference.
    07-25-2016 10:07 PM
  2. mhinc's Avatar
    Yuppers. Download Samsung Smart Switch for MAC. You can update it via the MAC rather than OTA.
    07-25-2016 10:34 PM
  3. shaidaz's Avatar
    What's the next step? I'm not trying to transfer my phone to this one, I want to use this phone for a separate purpose.
    07-25-2016 10:58 PM
  4. shaidaz's Avatar
    What now?
    07-25-2016 11:18 PM
  5. shaidaz's Avatar
    07-25-2016 11:19 PM
  6. shaidaz's Avatar
    Thanks but nothing seems to happen when I tried that. I don't get the "update software" option and when I go to emergency software recovery, my device doesn't show up at all
    07-25-2016 11:20 PM
  7. shaidaz's Avatar
    Nor does it show up under software update under the preferences option.
    07-25-2016 11:21 PM
  8. shaidaz's Avatar
    @mhinc, any ideas what the problem might be (see above)? Do I need an SD card in there? Do I need to remove my old SIM card?
    07-25-2016 11:27 PM
  9. mhinc's Avatar
    I am not too sure what to tell you on that one. You can try the old version of SmartSwitch Samsung Kies.
    Kies | Samsung CA
    07-26-2016 05:40 AM
  10. anon(632115)'s Avatar
    You cannot update AT&T devices using Kies or Smart Switch. Their updates are only available OTA for those on the AT&T network
    07-26-2016 06:47 AM
  11. mhinc's Avatar
    That explains it, Good to know, I am Canadian and all providers here allow it.
    07-26-2016 11:14 PM
  1. Replies: 2
    Last Post: 07-25-2016, 10:29 PM
  2. How to exit out of an app and go to the home screen on Moto X
    Last Post: 07-25-2016, 10:24 PM
  3. How do I plug my galaxy 3 tablet 8.0 to my flat screen tv
    Last Post: 07-25-2016, 10:23 PM
  4. Replies: 1
    Last Post: 07-25-2016, 10:21 PM
