1. endimerkuri's Avatar
    i rooted my phone with kingroot and then i wanted to install supersu. i downloaded and installed it and it said that there was a supersu binary update needed. i didn't update it than when i was trying to give access to supersu and uninstall kinguser the phone said that i had to reboot and try again. i rebooted and when the phone turned on it was very slow and it rebooted again after 2 minutes of usage. this continues to happen every time i try to turn on my phone. i have no recovery installed and the phone doesn't boot on safe mode. please help me
    07-27-2016 06:17 AM
  2. H3aTeRzz's Avatar
    Hi and welcome to AC Forums!
    My suggestion would be to find your OEM software at Sammobile.com and use Odin to reflash it. Then I would suggest not trying the Kingo Root method.
    Chris
    07-27-2016 07:38 AM
  3. endimerkuri's Avatar
    Thank you very much. It worked.
    07-27-2016 11:01 AM
  1. Replies: 2
    Last Post: 03-18-2017, 04:16 AM
  2. Is my phone water damaged?
    By V278 in forum Samsung Galaxy S6 edge+
    Last Post: 07-27-2016, 07:42 AM
  3. My cell phone was hacked by ex boyfriend
    Last Post: 07-27-2016, 06:24 AM
  4. Replies: 1
    Last Post: 07-27-2016, 06:21 AM
  5. HP laptop has stopped recognising my Hudle tablet
    Last Post: 07-27-2016, 06:10 AM
