So the other day my s4 fell on its bottom by the charging port an blanked out. Tried turning it on an the screen jus flicker white. I decided the LCD got broken.
Next week I got a crack but working screen from a friend, same model everything. So I jus put my motherboard an other stuff in the cracked phone. Turned it on, everything worked. When I pressed to put the backcover on, the phone blackout.
I took out the battery an put it back in. Turned it on, working fine. Same thing again when tried to put on the backcover, especially around the power button area when pressed down.
Any fix any one? Thank-you in advance
