1. Artistea's Avatar
    I have a Samsung galaxy S4 that's prepaid. Now, my question is, should my phone be able connect to public WiFi without data? Because it doesn't, and every time I tell my friends this problem they get all confused as if it shouldn't happen.
    08-24-2016 09:20 PM
  2. mhinc's Avatar
    Absolutely, your phone should have no issues connecting to public wifi or any wifi connections for that matter without having Data.
    What happens when you try to connect to a public network?
    08-24-2016 09:37 PM
  3. Artistea's Avatar
    It says im connected, but nothing works. I also get a notification that says iv run out of data and that I need to buy more.
    08-24-2016 11:27 PM
  4. Artistea's Avatar
    08-25-2016 05:19 PM
  5. mhinc's Avatar
    Hmm not sure if the S4 has the feature that I am thinking could be causing this. if you go into Settings, then MORE CONNECTION SETTINGS then see if Download Booster is on if you have it. This should not be on, it will try to use DATA and WIFI combined to get faster downloads. And if it's on and you have no data I can see this causing the issue.
    Not sure if the S4 has this option though let me know
    08-25-2016 10:02 PM
  6. Artistea's Avatar
    Yea its not an option.
    08-27-2016 05:02 PM
  1. Replies: 3
    Last Post: 09-23-2016, 04:06 PM
  2. How can I set monthly billing cycle?
    By jemez in forum Honor 5X
    Last Post: 08-26-2016, 02:38 PM
  3. What will I lose on my phone if I remove Dropbox?
    Last Post: 08-25-2016, 06:10 AM
  4. Replies: 0
    Last Post: 08-24-2016, 09:14 PM
  5. Why can't S5 find my Epson printer?
    Last Post: 08-24-2016, 09:09 PM
