1. clorde's Avatar
    I cannot change my lock screen settings message reads disabled by administrator, encryption policy or credential storage. Can anyone suggest how I can fix this?
    09-07-2016 05:59 AM
  2. Count Chokula's Avatar
    Your problem may possibly be due to an active administrator account which is preventing you from being able to change your lock screen settings. To fix this, go to settings–>security–>device administrators. From there you should be able to see which administrators are enabled (they'll have checked boxes beside them). Uncheck to disable.
    09-07-2016 06:45 AM
  3. clorde's Avatar
    I unchecked both s voice and android device manager. My lock screen is pattern but I cannot change it to swipe or none as those options are not hi-lighted
    09-28-2016 02:40 AM
  1. Samsung Gear S2: Update
    By Matt_james_matt in forum Samsung Gear S2
    Last Post: 09-09-2016, 10:20 AM
  2. How can I reset my Home Time Zone on a Galaxy S6?
    Last Post: 09-07-2016, 05:57 AM
  3. My HuaweiY511-U10 keeps on losing signal.
    Last Post: 09-07-2016, 04:40 AM
  4. Replies: 1
    Last Post: 09-07-2016, 04:38 AM
  5. Replies: 0
    Last Post: 09-07-2016, 04:14 AM
