1. sherrard12's Avatar
    I bought a kranich 7500mah battery to replace my s4 stock battery. but when i use the kranich battery i barely get any signal. i would like to avoid going back to the stock battery.
    10-02-2016 02:33 PM
  2. srkmagnus's Avatar
    It all depends on the casing material of the battery as well as the size of the battery. I would not believe it to be a significant detractor to cell signal; however, if you are in areas with very limited signal then the added thickness of the battery/case could be a factor. Before you rule out using this battery, have you performed a factory reset just to clear everything and start fresh with the new battery? Backup/sync your data before hand and be sure to give it a day or two worth of use before making a final decision.
    10-02-2016 02:36 PM
  3. sherrard12's Avatar
    Yes i have factory reset with battery in phone
    10-02-2016 02:37 PM
  4. prasad219's Avatar
    I feel the thickness of your new battery is blocking the signal. It must be covering up the antenna and mostly because of the thickness or maybe the material used in the battery is also affecting your signal strength.
    10-02-2016 03:16 PM
  1. New Urbane 2 LTE with iOS Battery Issues
    By Greekbull in forum LG Watch Urbane 2nd Edition
    Last Post: 10-05-2016, 12:21 PM
  2. Night Battery Drain
    By Grim Reaper in forum Samsung Galaxy Note 5
    Last Post: 10-02-2016, 04:38 PM
  3. Do batteries affect cell signal?
    Last Post: 10-02-2016, 04:32 PM
  4. All I want to do is remove picassa pics, I deleted Google +
    Last Post: 10-02-2016, 03:04 PM
  5. Replies: 1
    Last Post: 10-02-2016, 02:53 PM
