1. nsharma2's Avatar
    I have an aftermarket Bluetooth adapter in my old crappy car which connects to my phone through Bluetooth and outputs the sound to my speakers through an FM transmitter. The phone audio streams perfectly to the car speakers, but the issue is that the person on the other end cannot hear me because my mouth is nowhere close to the microphone on the unit (which is plugged into my car's cigarette lighter).
    Ideal solution is to use my phone's microphone instead of the aftermarket device's while still routing the audio out through Bluetooth. Is this possible? I am rooted and am willing to tinker around in areas of the phone no one should dare go...
    I did some Googling to no avail. I've downloaded SoundAbout thinking it might be able to, but no dice.
    Thank you in advance!
    10-27-2016 04:00 PM
  2. Rukbat's Avatar
    Not possible unless you're willing to modify both the hardware and the ROM.
    10-27-2016 04:04 PM
  3. nsharma2's Avatar
    Modifying the ROM I could potentially deal with. The hardware is another story...
    10-27-2016 04:07 PM
  1. How to keep super close macro shots on the S7 Edge on Pro Mode
    By smooth4lyfe in forum Samsung Galaxy S7 edge
    Last Post: 09-17-2017, 12:53 PM
  2. Can i Stream from my smartphone to smart tv without wifi
    Last Post: 10-28-2016, 02:40 AM
  3. New to Pixel, notification questions
    By fwellers in forum Google Pixel & Pixel XL
    Last Post: 10-27-2016, 10:34 PM
  4. why does droid mini battery overheat and quickly discharge?
    Last Post: 10-27-2016, 03:43 PM
  5. I'm lost (so many smartphones to choose from!)y
