1. ozstar's Avatar
    Hi,
    I have had a Galaxy S4 (GT-l9505) since new (maybe 2 + years) but recentlky the charging has gone crazy.
    Android 5.01 Build ID LRX22C
    It seems to go thru charge quite quickly (more than before) and charges very very slowly.
    I have tried several charges, leads, bought a new battery yesterday (it was 29% charged) a montn ago had a new port and board put in and still all the same problem.
    I now have Ampere and on 1 charger got 300 and now another 360 but that is max I can get out of 6 chargers including fast ones.
    Whe no charger is in it shows -460 with max drains..
    Telstra 43% Screen 37% Android 14% Android OS 10%
    I tried to safe boot. Home- Vol Up- On/Off and got a very small blue line at top then it went back into the Glaxy S4 black screen white writing.
    It have it now goiing up 300Ma min/max 17% temp 28.2 Volatge 3.732
    Any help please?
    Thanks
    oz
    PS I also have a Note 5 with wireless charge ir it charges well.
    11-09-2016 03:49 PM
  2. Rukbat's Avatar
    The battery seems to be shot - a 1 Amp charger should be able to charge the battery at a MUCH higher rate than 300mA. (Especialy if you're draining the battery past 40% before charging, regularly - that can kill a battery in months.)
    Replace the battery. https://www.amazon.com/Battery-Anker...cUvbUpU5554957 is a good one (but it's $13). https://www.amazon.com/Samsung-EB-B6...cUvbUpU5554957 is an original Samsung, and it's only $5. It's your choice.
    11-09-2016 04:24 PM
  3. ozstar's Avatar
    Hi,
    Thanks for the help.
    I bought a new battery yesterday here is Sydney Oz ($42) and it was 29% when I firts placed it into the phone. It was going down to 14% between placing it on different chargers and leads.
    Now it got up to 20% at 300mA then I turned it off to see if it went faster.
    Been off now 25 mins and is now 26% on the geen battery on screen.
    To try and keep my usage down, I will kill as many apps as I can.
    I seem to have a lot of Google apps on and also Samsung apps. I don';t use any to my knowledge.
    What ones can I uninstall without problems?
    Thanks again
    11-09-2016 04:43 PM
  1. Replies: 8
    Last Post: 11-17-2016, 10:40 PM
  2. Replies: 1
    Last Post: 11-09-2016, 04:32 PM
  3. How do I get a £ on keyboard on Samsung galaxy tab s2d
    By jude ha in forum Samsung Galaxy S2
    Last Post: 11-09-2016, 04:27 PM
  4. Replies: 0
    Last Post: 11-09-2016, 02:43 PM
  5. Problems with contacts names
    Last Post: 11-09-2016, 12:43 PM
