Save big + get 3 months free! Sign up for ExpressVPN today
  1. ricardo_beatles's Avatar
    My battery drains too fast, using my phone continually it can discharge in about 3 or 4 hours. I have installed FirstFlight N7 Themed V6 ROM, in the stock lollipop rom this also happened. I installed Ampere app to measure how much current my phone was charging and discharging and when the charger is not plugged in, it discharges at 460mA, is that normal? I bought a Samsung 2A charger and it charges at 600mA or maximum 700mA but I changed the usb cable of the charger and it charges at 860mA or maximum 900mA. I don't understand because it should charge at 1900mA, shouldn't it? how do I reach that? I need to mention that I charge the phone directly in a wall, not in a usb port, and why does my battery drain too fast? I need help. The model of my S4 is I9500
    Attached Thumbnails My Galaxy S4's battery drains too fast and the charger doesn't charge how it should-screenshot_2017-05-28-11-48-55.jpg   My Galaxy S4's battery drains too fast and the charger doesn't charge how it should-screenshot_2017-05-28-11-49-14.jpg   My Galaxy S4's battery drains too fast and the charger doesn't charge how it should-screenshot_2017-05-28-11-50-21.jpg
    05-28-2017 03:21 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Have you already tried a new or different battery?
    05-28-2017 04:55 PM
  3. ricardo_beatles's Avatar
    Thank you! yes, I bought a new battery two months ago and there was a diference but not much, the old one discharged faster than this, I think the battery I bought is not an original one
    05-28-2017 06:44 PM
  4. B. Diddy's Avatar
    Ok -- sorry, but that's probably the most I can contribute to this thread, since I don't know the technicalities of charging rates, especially in the context of a custom ROM. Hopefully someone else has some good insight!
    05-28-2017 06:54 PM
  5. slimchap's Avatar
    Hi Ricardo, how fast does your phone charge?;since you say that your phone charges with 700ma and 600ma I think the charger does not charge it accurately. I use to have battery related issues before until I downloaded Ampere and found out that most chargers I bought were actually charging my phone with tiny bits of current. But changing my charger to one that chargers with 1000ma and 2000ma with the help of Ampere I don't suffer Battery related issues anymore.
    05-28-2017 07:03 PM
  6. ricardo_beatles's Avatar
    I'm not completely sure but it takes 3 or 4 hours approximately using the other usb cable, but charging with the one which charges at 700mA it can take even more. I'm starting to think the Samsung charger I bought is not a real 2 amp charger. Any idea why it discharges at 460mA? it looks to be too much current to be discharging at, or is it normal? really thank you!
    05-28-2017 07:37 PM
  1. What does it mean why is it on phone
    Last Post: 09-13-2017, 11:29 AM
  2. Calendar widget doesn't load data
    By HowardL168 in forum Moto Z
    Last Post: 06-29-2017, 07:15 AM
  3. Need my email address to login to facebòok account
    Last Post: 05-29-2017, 01:24 AM
  4. Why does my s5 keep going into charging mode
    Last Post: 05-28-2017, 04:56 PM
  5. How do I get rid of pre-installed entries on calendar?
    Last Post: 05-28-2017, 03:19 PM
