1. ricardo_beatles's Avatar
    Hello xda member I have a problem with my S4 (I9500) battery consumption and I would like you to help me. Well, It can't be normal that my phone consumes that quantity of current, I mean, 460mA? isn't that too much current? It doesn't matter what I am doing, it is always the same quantity, never consumes less, I have tried turning off the wifi, mobile data, location, sync, even I turn on airplane mode and power saving mode and it's the same, the number of mA doesn't change, , I have to mention that I always use the brightness in the minimum. I installed Gsam Battery Monitor app and it shows that the mayor part of the battery consumption is in apps and within it it shows that the kernel and Android System consumes too much battery, is that normal? I have tried everything and I haven't found any solution for this, I really need help
    Kernel version: 3.4.5-VoLTaqe root@voltaqe #1
    ROM version: FirstFlight N7 Themed V6
    S4 I9500
    Just in case, this also happened in the stock rom, indeed I changed the rom looking for solving this
    Attached Thumbnails I need help with my S4 baterry, it drains extremely fast-screenshot_2017-06-03-00-29-10.jpg   I need help with my S4 baterry, it drains extremely fast-screenshot_2017-06-03-00-29-19.jpg   I need help with my S4 baterry, it drains extremely fast-screenshot_2017-06-03-00-29-30.jpg   I need help with my S4 baterry, it drains extremely fast-screenshot_2017-06-03-00-29-48.jpg
    06-03-2017 01:30 PM
  1. I can't stop syncing contacts to my phone
    Last Post: 06-04-2017, 06:47 PM
  2. Replies: 3
    Last Post: 06-04-2017, 06:45 PM
  3. My htc goverment keeps locking up
    Last Post: 06-03-2017, 01:27 PM
  4. How do i send my games and progress to my tablet.
    Last Post: 06-03-2017, 12:56 PM
  5. Why my cute emoji keyboard dont work
    Last Post: 06-03-2017, 12:55 PM
