10-02-2015 06:22 PM
64 123
tools
  1. Northern.dj's Avatar
    Yep the usb cover is a week point if the S5 came out cordless from the start then maybe we would have covers by now
    one other advantage is the camera is not touching the surface may have to adapt a cover to fit
    06-03-2014 06:24 PM
  2. ilordvader's Avatar
    Its the best Accessories i ever got
    06-05-2014 02:38 PM
  3. Pa Bi's Avatar
    I bought this wireless charger for $18.99
    It fits inside the stock S5 plastic case, no bulges created on the back.
    I did lay a piece of business card over the charging contacts.
    Measured about 3/8" x 1", without it the contacts were intermittant.
    This one => * Qi Standard Wireless Charger kit 'mine'
    It comes with the charging pad making this one a really great deal.
    HI AZgl1500, can you post your battery temperature screen when charging using this kit? Thank you a lot in advance.
    06-06-2014 02:23 AM
  4. Eclipse2K's Avatar
    I ordered the Charging Cover OEM and Tylt Vu Qi charger. Going to pick up a Belkin bumper as suggested and be done with the port cover. Getting rather tired of fiddling with it in the dark.
    Samsung Galaxy S5 (Verizon)
    06-10-2014 01:16 AM
  5. Eclipse2K's Avatar
    Ask and you shall receive.
    https://forums.androidcentral.com/e?...token=y5qJRWqs
    So I tried the case and at least with the standard cover I can't stand it. The case is too flimsy on the edges and I can feel movement due to this. So I need to find something solid or return my new wireless cover.
    06-11-2014 08:43 PM
  6. ThrottleAbuse's Avatar
    So the official samsung cover makes the phone to thick to fit in most cases? I was really hoping to get this accessory and get an ottterbox defender or commuter. Maybe I won't be getting a S5
    06-12-2014 12:36 AM
  7. Eclipse2K's Avatar
    3mm thicker so that is correct. An Otterbox won't work.
    06-12-2014 01:31 AM
  8. Pa Bi's Avatar
    Anyone can post the temperature range when using OEM wireless cover???
    06-12-2014 05:19 AM
  9. Eclipse2K's Avatar
    Got my wireless charging cover today. I've tried every case I have (Tudia, Diztronic, Spigen SlimArmor, and Cruzerlite) and none fit.
    Gonna return the cover since Bumpers seem iffy after trying one (for me, the Belkin did fit).
    06-12-2014 04:21 PM
  10. ThrottleAbuse's Avatar
    So lame. Guess I need to find out more about the G3
    06-12-2014 06:08 PM
  11. Eclipse2K's Avatar
    I found out one of my cases work with the OEM Samsung Wireless Charging Cover!
    https://forums.androidcentral.com/e?...token=QqtJU-vV
    This case works NEARLY flawlessly. The issue is installing it is tight and if you happen to put it in the case incorrectly the volume and power buttons will not line up. If you do it correctly everything will line up and the phone is protected with all port openings still in check.
    Tight fit but at least it works. The chrome is covered from edge to edge. It is a bit annoying though if you get it wrong.
    06-12-2014 11:22 PM
  12. f308gt4's Avatar
    I'm using a Diztronic case on mine. It's not a perfect fit, but it works OK. It's a quality case to begin with, so even with a not so perfect fit, it's still acceptable for me for daily use.
    06-13-2014 04:46 PM
  13. Eclipse2K's Avatar
    It doesn't fit though. I mean any TPU will generally "fit" by some standard but I noticed that it can pull loose easily and cause the alignment of the power/volume buttons to be off.
    If you like it that's great. Not saying there's anything wrong with it. Just not ideal for myself.
    06-13-2014 05:13 PM
  14. ssgokou29's Avatar
    Mobile Phone Accessories & Smartphone Accessories | Samsung
    I dont know if it's the samsung website or your link, but your link just take me to the samsung home page...Do you have the case name?
    Thanks,
    06-16-2014 11:55 PM
  15. Eclipse2K's Avatar
    Thanks,
    Galaxy S5 Protective Cover Clear
    Galaxy S 5 Protective Cover, Clear
    Sorry about the bad link.
    I will note though that I stopped using the case within a day. It works as well as any case will with the cover but I decided to go with a Belkin Grip Bumper.
    06-17-2014 12:17 AM
  16. ssgokou29's Avatar
    Just got my wireless charging back tonight. Works and def and some bulk and weight as others have said.
    This is the charging pad i have (http://www.amazon.com/RAVPower%C2%AE...cUvbUpU3720633)
    Will def need another one for work might pick up the samsung one since i have a coupon. Charging def seemed slower of course compared to plug in the wall, but not too bad i guess.
    Batt temp got up to 104f which sucks as wall charging doesn't really heat up that much or at all.
    Now the hunt for a case with kickstand, as my old one doesn't work now with the wireless charging.
    06-20-2014 01:28 AM
  17. Eclipse2K's Avatar
    This is the charging pad i have (http://www.amazon.com/RAVPower%C2%AE...cUvbUpU3720784)
    I haven't checked my S5 constantly but after an hour on my Tylt Vu the temperature was around 94 degrees. Do you use a case? I'm using a bumper case so my charging back is wide open and no heat gets trapped.
    06-20-2014 04:44 AM
  18. ssgokou29's Avatar
    Not yet, but i will need to eventually. Do you have the OEM wireless back? or a pad? I'm thinking of picking up the Tylt, to use as my work charger.
    06-20-2014 10:27 AM
  19. ssgokou29's Avatar
    been on the charger for about 30 mins. Taking it off here and there to answers messages, incase people wanted to see the temp in action
    Attached Thumbnails Qi Wireless charger w/Receiver for Galaxy S5-screenshot_2014-06-20-10-39-44.jpg
    06-20-2014 11:43 AM
  20. Eclipse2K's Avatar
    Yes, OEM back. Tylt charging dock.
    06-20-2014 04:35 PM
  21. ThrottleAbuse's Avatar
    Any idea the charging specs on the VU-Mate Card? Wonder how it compares to the Itian one the guy linked on Ebay.
    06-25-2014 06:46 PM
  22. ilordvader's Avatar
    Hi
    Can you please tell me
    which are the Apps you have
    1) showing battery meter
    2) your phone data & mins
    Thanks
    Attached Thumbnails Qi Wireless charger w/Receiver for Galaxy S5-0screenshot_2014-06-20-10-39-44.jpg
    06-26-2014 01:26 AM
  23. Eclipse2K's Avatar
    Hi
    Thanks
    The battery meter I'm unsure of as it could be many. I use GSAM personally but that's not what theyre using.
    The data appears to be a T-Mobile My Account application.
    06-26-2014 01:59 AM
  24. teristark's Avatar
    I picked this one up too. It took 10 days to arrive. I love the wireless charging. It works with my case BUT it gets very warm. I will check temp on the next charge and post the results. I will also try it without the case and see if it is any cooler. This is the case I use:
    ULAK Waves Wallet
    07-20-2014 03:34 PM
  25. ThrottleAbuse's Avatar
    I got one of these too. I ordered it on the 10th and got it today. Barely adds any bulge to the phone. If you wanted to make it slimmer you could remove the little tabs on the battery cover that stick out and it would probably take the bulge out completely. Seems a bit warm after charging from 90-100%, but I never really paid attention to how warm it got plugged in. Best of all it works in my Otterbox Defender. I installed the GSAM app so I will let you guys know on the temps.
    07-21-2014 05:58 PM
64 123
  1. APN Settings for AT&T M8 used on T-Mobile??
    By Lilshaq65 in forum HTC One M8
    Last Post: 09-18-2014, 07:50 AM
  2. Any faith left for sprint
    By choclab1 in forum Google Nexus 5
    Last Post: 06-15-2014, 12:49 AM
  3. AllShare Cast Wireless Hub
    By John Ball1 in forum Samsung Galaxy Note Pro 12.2
    Last Post: 05-03-2014, 04:20 PM
  4. Verizon galaxy s4 from 4.2.2 to kitkat
    By UNCMo96 in forum Verizon Samsung Galaxy S4
    Last Post: 05-01-2014, 03:14 AM
  5. [VIDEO] AT&T Galaxy S5 - Standalone Visual Voicemail
    By chrisngrod in forum Samsung Galaxy S5
    Last Post: 04-30-2014, 09:54 PM
