1. Thegreatone3's Avatar
    Recently purchased the OEM Galaxy S5 spare battery kit from Samsung's official site. I noticed that the included wall charger is rated at 0.7 amps/5V (USB 2.0). The stock charger that shipped with my Verizon S5 is 2.1 amp/5.3V (USB 3.0).
    Any harm in using my phone charger and cable for the battery kit? It can accommodate USB 3.0. There's quite a difference in power and I'm wondering if there's a battery longevity issue with using the higher amp charger. Thank you!
    Ferdind Ferdi likes this.
    10-24-2014 08:20 AM
  2. cliffclaventoo's Avatar
    I have the same question
    T-Mobile White Galaxy S5
    12-06-2014 06:47 PM
  3. ImNoPrince's Avatar
    The Charger should only use the Amperage it needs . They ship it with a lower rated one as that's all that is needed to charge the battery, the Phone one is higher as they know you might be using other functions on the Phone while charging the battery as well. But the standalone will still only pull the .7 it needs off the higher charger .
    It's like putting a new LEd bulb in a light fixture the old ones need that 60watts but the LEd only needs 20 or so and will only draw that.
    If that was an issue of over draw it would blow the LEDs every time.
    12-07-2014 09:17 PM
  1. S5 (Verizon) Can't access SD Card HELP
    By knicks1130 in forum Samsung Galaxy S5
    Last Post: 11-01-2016, 12:13 AM
  2. Factory Reset question
    By rjack22 in forum Motorola Droid MAXX
    Last Post: 10-24-2014, 12:12 PM
  3. will updating my samsung galaxy s4
    By Lash Ruth in forum Samsung Galaxy S4
    Last Post: 10-24-2014, 07:13 AM
  4. Battery Lazarus Effect
    By BlueBlazer60 in forum Droid RAZR M
    Last Post: 10-24-2014, 06:01 AM
