1. togman's Avatar
    What is the BEST battery replacement that will fit just like the OEM battery but have a longer battery life with more mAh?
    10-30-2014 10:43 AM
  2. Sophiania's Avatar
    Have no idea about the best battery replacement, but i think you can always take another OEM battery together with you, and you have two 2800mAh batteries, that's 5600mAh. And that seems much safer.
    10-31-2014 12:26 AM
  3. togman's Avatar
    So no one has any other ideas??
    11-05-2014 09:03 AM
  4. Mst99's Avatar
    I've had cheap Chinese knock off batteries, and pricey brand name ones. Extended and regular. Both brands start out good then after a few months lose their battery capacity. I now just buy one or two extra oems with the oem charger and I am good to go. But I'm sure someone will chime in about a good experience with one. Be very skeptical of higher listed mAh in the same oem dimensions.
    togman likes this.
    11-05-2014 09:44 AM
  5. StevenBaker's Avatar
    Lithium Ion battery is designed specifically for your Samsung Galaxy S 5 to deliver the most reliable and long lasting power (2800 mAh). This battery is equipped with an NFC antenna, allowing your handset to communicate with other devices and accessories equipped with NFC technology.
    11-11-2014 01:21 AM
  1. Can anyone help me root my SAMSUNG-SGH-I537?
    By ariel12345263 in forum Ask a Question
    Last Post: 11-20-2015, 01:18 AM
  2. How can I unbrick my Galaxy S4?
    By Sudha Dubey in forum Ask a Question
    Last Post: 10-31-2014, 12:32 PM
  3. Replies: 3
    Last Post: 10-30-2014, 06:23 PM
  4. Help finding this leather case for Galaxy Note 4
    By wrl-2 in forum Samsung Galaxy Note 4
    Last Post: 10-30-2014, 11:33 AM
  5. Replies: 1
    Last Post: 10-30-2014, 09:55 AM
