1. Shams H's Avatar
    I have the S-view cover for quite some time now, I never had any problem with it,, or so I thought.
    today my friend pointed that the cover increases the battery drain (which is already bad) on the S5, and I wanted to check that so I tested screen on time with the cover on, then off.
    when it was on Screen on time was 2h 33m ,,,, when I took it off it became 4h 46m !
    does anyone know what the issue is ?
    11-01-2014 12:32 PM
  1. note 4 android system battery drain
    By Samuel Boynton in forum Samsung Galaxy Note 4
    Last Post: 11-08-2014, 06:11 AM
  2. Replies: 1
    Last Post: 11-01-2014, 05:08 PM
  3. Replies: 2
    Last Post: 11-01-2014, 03:19 PM
  4. Replies: 1
    Last Post: 11-01-2014, 01:09 PM
  5. Replies: 0
    Last Post: 11-01-2014, 07:02 AM
