1. smooth4lyfe's Avatar
    So I have this charger, and thought I just share my experience with it. Might be useful for anyone who needs it!
    http://www.amazon.com/dp/B00TDHEFNY?...cUvbUpU4598711
    The Coocheer 5 USB Hub is a GREAT device! It’s small, portable and convenient.
    Features:
    The Coocheer 5 USB hub has three 1.0 amp USB ports and two 2.4 amp charges. This devices will charge your devices t the fastest speeds possible. It really works! I am able to charge my devices and come back to them fully charged when I need them. The two super charge ports are good for devices like the Galaxy S6. Its not Quick charge, but it’s a good equivalent
    Quality:
    The Coocheer is a quality device. Does not look or feel “cheap”. This device also does not overheat when charging, which is a plus for safety. This device also seems durable. I have accidently dropped this device and it still works really well (Not that you should try it).
    Convenience:
    This device is small and portable enough to fit in your pocket, a laptop bag, or any carry bag. You would need an outlet to plug in the device and charge your devices., but its easy to use.
    Overall:
    I would recommend this device! Its small and portable, it’s durable, and charges fast.
    08-09-2015 09:22 PM
  1. how do I get usb drivers for blu ray writer
    By jiminii in forum Ask a Question
    Last Post: 08-09-2015, 06:25 PM
  2. How can I disable wrong charger notification?
    Last Post: 08-09-2015, 06:11 PM
  3. Will USB type C really become the standard?
    By josepepepe771 in forum Ask a Question
    Last Post: 08-09-2015, 05:02 AM
  4. External S5 Battery Charger for Car
    Last Post: 08-08-2015, 10:35 AM
