1. Penthor's Avatar
    Anyone know where I can get a new OEM lens and bezel? My local repair shop didn't have one, and I didn't find one on eBay.
    BTW great app!
    10-04-2014 11:22 AM
  2. AugustArborists's Avatar
    First, welcome to AC, it's a fun place. Second, I would check Ebay, sooner or later everything ends up there. Third, How did you break the lens? I've heard of the regular S5 lens breaking, yours it the first Active needing replacement. I'm just curious.
    10-05-2014 03:54 PM
  3. Penthor's Avatar
    I searched every related term I could think of on eBay at the recommendation of the local repair shop. No luck. I'm not sure how the lens broke. It's only a month old. However, the bezel/lens extends out past the battery cover. When the phone is set down screen up, it rests on the bezel. Maybe I set it down too hard. That seems to be a design flaw. So far the camera still takes good pics. I think I can install a new bezel/lens myself if I can find one.
    10-05-2014 06:21 PM
  4. Resendetra's Avatar
    A lot of people have had this problem with the S5 and the Active. The bezel does stick a bit too far out, so when someone sets the phone down, the hard surface is going to hit the lens. I bought the hula bumper case for mine, it made it so the bezel isn't hitting surfaces all that much.
    Sent from my Galaxy S5 Active using Tapatalk
    10-05-2014 08:32 PM
  5. glokk953's Avatar
    BTW great app!
    Did you ever find one. I need one
    10-27-2014 09:49 PM
  1. Replies: 7
    Last Post: 10-04-2014, 12:13 PM
  2. Replies: 1
    Last Post: 10-04-2014, 10:37 AM
  3. Replies: 2
    Last Post: 10-04-2014, 07:02 AM
  4. Need help with a sticky touchscreen.
    By Homeboy88 in forum HTC One M8
    Last Post: 10-04-2014, 03:08 AM
  5. Replies: 0
    Last Post: 10-04-2014, 12:56 AM
