1. Skip Marler's Avatar
    I am trying to root my s5 active with the latest active software release. It is not the same as all the solutions I have found that are for the S5. Towel does not work, is there a similar solution?
    Please Help!!!
    Skip
    10-15-2014 07:56 PM
  2. bigwillyg's Avatar
    You have to flash the kernel from the previous version then use towel root. Then flash back to the current kernel
    Sent from my SAMSUNG-SM-G870A using Tapatalk
    11-02-2014 10:48 PM
  3. H3aTeRzz's Avatar
    Confirmed: This does work...
    TowelRoot Samsung Galaxy S4/S5 and Note 3 on Android 4.4.2 NF or Later - W0lfDroid
    NOTE: Be sure to download the correct version of the 2 different files. For example, I was downloading the ones for the S5 and not the S5 Active. But it does work!
    oditius likes this.
    11-07-2014 07:34 PM
  1. What phone are you leaving for the Nexus 6?
    By I Can Be Your Hero in forum Google Nexus 6
    Last Post: 02-28-2015, 05:34 PM
  2. Note 4 - How did it go picking it up at Best Buy?
    By reesh11 in forum Samsung Galaxy Note 4
    Last Post: 11-10-2014, 11:21 PM
  3. Are you getting the Nexus 6
    By Chetan Takyar in forum Google Nexus 4
    Last Post: 10-22-2014, 07:57 PM
  4. JELLIES! (Catch them all) - Free game for Android
    By juanmontes in forum Android Games
    Last Post: 10-16-2014, 01:59 AM
