1. Isaac Felder's Avatar
    The volume up button works with the volume down button will not work on my s5 galaxy active
    09-06-2015 06:14 PM
  2. srkmagnus's Avatar
    You'll need to have it repaired. Is the device still covered under warranty?
    09-06-2015 06:17 PM
  3. none_other_than's Avatar
    If it's not under warranty, you may have to take it to a store that can fix it. However, if you don't want to spend that much or something, there's an app I use called All In One Gestures that allows you to set up gestures to change settings (ex. swipe from the right side of your screen to turn volume down). I strongly recommend it, I find it really useful. It's on the Play Store.
    09-11-2015 09:24 PM
  1. Replies: 3
    Last Post: 01-19-2016, 12:12 AM
  2. Unlocked AT&T G850a: To root or not to root?
    By B3ing in forum Samsung Galaxy Alpha
    Last Post: 09-13-2015, 05:24 PM
  3. Replies: 2
    Last Post: 09-06-2015, 06:30 PM
  4. How can i check my message history on samsung note 2 phone
    Last Post: 09-06-2015, 06:18 PM
  5. Replies: 1
    Last Post: 09-06-2015, 06:12 PM
