1. Adam Benko's Avatar
    How can i transfer files to S5 mini using cable ? When i select the option to transfer media files , some stupid program appears on my pc but it wont let me to transfer media. I just want to see my S5 mini as my Note 3. Want to see it as hdd , how can i do it ? thx.
    12-26-2014 08:13 AM
  2. B. Diddy's Avatar
    Connect your S5 to your computer via USB. If anything pops up on the computer prompting you to install something (which is a typical Verizon thing to do), just exit out of that popup without accepting anything.
    On your phone, swipe down the notification shade and tap on the USB Connection notification. Make sure it's set to MTP. On your computer, open Windows Explorer (assuming you have a PC), and look for S5 Mini as a device listed on the left column. Click on it, and you should be able to explore its folders. The phone's lockscreen has to be unlocked before the computer can get access. You can use Windows Explorer to drag and drop files from the computer to the phone.
    Keep in mind that the S5 cannot connect as a "USB Disk Drive" or "USB Mass Storage," since that is an outdated form of connection which was phased out around the time of Ice Cream Sandwich.
    12-27-2014 04:08 AM
  3. AKFL3TCH3R's Avatar
    Try android files transfer.
    01-10-2015 10:06 PM
  1. Replies: 4
    Last Post: 12-28-2014, 01:17 AM
  2. --- Please Note -- there is a problem with the forum engine - Users Unable to re-login
    By fabio_again in forum New to the Forums? Introduce Yourself Here!
    Last Post: 12-26-2014, 02:03 PM
  3. Can I send a rooted/bricked Sprint LG G2 back to Asurion?
    By Kait Moreno in forum Ask a Question
    Last Post: 12-26-2014, 09:29 AM
  4. How can I phone my voicemail?
    By Julia Thomas1 in forum Samsung Galaxy S5 Mini
    Last Post: 12-26-2014, 07:52 AM
  5. Replies: 0
    Last Post: 12-26-2014, 07:19 AM
