1. anon(9132702)'s Avatar
    Hello,
    I would like to root my samsung galaxy s5 without tripping knox I have verizon, but towlroot won't work I looked into kingo but I'm not sure if it will trip knox I have SM-900V andriod version 4.4.2 build number KTU84P.G900VVRU1ANI2 and the newest verizon update
    Could anyone tell me a root application that will root my phone without tripping knox on my phone?
    Ps. sorry about the a after knox (Damn autocorect (no it was just be being dumb))
    PLEASE READ:
    I have successfully achieved root with knox 0x0 I downgraded my phone with a signed version! I NEEDS TO BE SIGNED. Then installed towelroot. Simple!
    Thanks,
    -x7r gaming
    10-12-2014 05:51 AM
  2. Golfdriver97's Avatar
    Welcome to the forums. As far as I know, there is no way to avoid tripping the Knox counter, or erase it. I believe that bounty is still active on XDA.
    10-12-2014 09:31 AM
  3. anon(9132702)'s Avatar
    I was looking on xda just now and I found somthing about flashing back to an old kernal then use towlroot would flashing back trip knox?
    10-12-2014 02:18 PM
  4. Golfdriver97's Avatar
    That might work for root, but not tripping the Knox counter to my knowledge.
    Sent from an AOSP M8
    10-12-2014 07:23 PM
  5. anon(9132702)'s Avatar
    Is there any way to root my s5?
    10-13-2014 05:02 PM
  6. Golfdriver97's Avatar
    Have you tried here: http://galaxys5root.com
    10-13-2014 07:07 PM
  7. anon(9132702)'s Avatar
    OK I have figured it it's easy with the right files
    I will post how on xda
    10-15-2014 01:01 PM
  8. carbear02's Avatar
    how do you know if you tripped knox or not?
    10-17-2014 02:41 PM
  9. anon(9132702)'s Avatar
    I'm just guessing it's probably triped so I won't post it
    10-18-2014 11:57 AM
  10. Eric Kaiser57's Avatar
    If you install "phone info Samsung" from the play store, it will show you the knox counter
    01-10-2015 04:45 AM
  11. bldg's Avatar
    Surely it can't be easy as downgrading the kernel then using towelroot. I'm guessing if you tried to flash the older kernel, it wouldn't let you, or it would trip knox.
    To see knox counter: boot into download mode. 0x0 = good 0x1 = bad.
    01-10-2015 09:51 PM
  12. anon(9132702)'s Avatar
    Actually It did not trip knox for me I have root and knox is 0x0
    01-10-2015 11:43 PM
  13. anon(9132702)'s Avatar
    It doesn't trip knox but you need a signed version or it will trip knox
    01-10-2015 11:48 PM
  1. access to google play services without a code, redeem?!
    Last Post: 07-07-2017, 11:43 PM
  2. Replies: 1
    Last Post: 10-13-2014, 01:54 AM
  3. Replies: 1
    Last Post: 10-12-2014, 09:26 AM
  4. Replies: 0
    Last Post: 10-12-2014, 03:42 AM
  5. How to make Galaxy S4 use speakerphone as default speaker ?
    Last Post: 10-12-2014, 03:06 AM
