1. nyubilala's Avatar
    The little sensor on the top right corner blinks red and turns my screen off whenever it is covered. I have searched through my settings to see if I can fix it but I couldnt find anything. Its really getting irritating! Does anybody know how to fix this? Thank you!
    11-25-2014 12:02 AM
  2. SpookDroid's Avatar
    Does it do that at all times? That's the proximity sensor and it really should only 'kick in' when you're in a call as it's used to turn your screen off when your phone is near your face to avoid cheek button presses.
    You could try booting into safe mode and see if it's an app you installed that's causing the issue.
    Power the Device Up in Safe Mode Samsung Galaxy S 5 | Verizon Wireless
    11-25-2014 09:24 AM
  1. Root life on the Tab S 8.4 is sweet 😎 do it now, trust me.
    By mxrider821 in forum Samsung Galaxy Tab S 8.4
    Last Post: 05-14-2015, 11:31 PM
  2. How do I stop text-to-speech on Sam Gal Tab Pro 10.1?
    By bobn151 in forum Android 4.4 KitKat
    Last Post: 11-26-2014, 10:01 PM
  3. How do I get a deleted thread back from Messeging?
    By Karrie Ringelstetter in forum Moto X (2013)
    Last Post: 11-26-2014, 12:54 PM
  4. How do I get rid of TWRP so I can update to 4.4?
    By Conor ODonnell in forum Nexus 4 Rooting, ROMs, & Hacks
    Last Post: 11-25-2014, 11:08 PM
  5. How do I get my emojis to work after update?
    By kmcginness23 in forum Samsung Galaxy Note 3
    Last Post: 11-25-2014, 02:10 PM
