1. kavi7788's Avatar
    I've got a Samsung Galaxy S5 (G900A model) that I successfully rooted and attempted to install the Cyangenmod 12 onto. That was unsuccessful so I attempted to restore to the original via Odin. Unfortunately, now the phone is displaying a solid blue LED and blank screen only.
    I did this because I dislike the Samsung Touchwiz and want a pure Google experience, like the Nexus. #Fail
    How I fix this??????????????????
    02-28-2015 01:18 PM
  2. Rukbat's Avatar
    Turn the phone off. Fully charge the battery. Leave it on the charger another hour.
    Plug the phone into your computer and flash the stock ROM for that model S5, for your country and carrier. (Flashing a ROM for a different model can do anything from work to cause electronic damage.)
    If it still doesn't work, bring it to your nearest AT&T Device Support Center. Just hand them the phone and say "it doesn't work". (It's under warranty - if you haven't fooled with it. If there's no system in it, who knows how it got erased?)
    02-28-2015 03:56 PM
  3. Hiba Tahir's Avatar
    connect your device with samsung kies make sure you have installed the usb drivers click on tools > firmware upgrade and inislization put your model and serial number thats all
    03-12-2015 06:25 AM
  1. Why does my touch screen go crazy while charging?
    By leelauer in forum Google Nexus 7 Tablet (2012)
    Last Post: 02-08-2019, 07:23 PM
  2. Replies: 2
    Last Post: 04-27-2015, 09:07 AM
  3. ZTE ZMax 970 impact resistent case and screen protector?
    Last Post: 03-06-2015, 11:59 AM
  4. Changing the way zoom works on android.
    By uandc in forum Software Development and Hacking
    Last Post: 03-06-2015, 11:52 AM
  5. Why doesn't my S5 have easy mode?
    By yasmin de los santos in forum Samsung Galaxy S5
    Last Post: 02-28-2015, 01:30 PM
