1. Ronald Moschorak's Avatar
    Ok so I rooted my Samsung GS5 4.4.2 (AT&T) with towel root. Everything worked great. So after a month or two, apps that needed root support stopped working and root checker said I wasn't rooted plus a seemingly massive power drain all without me doing anything related to the unroot process... Not only that, the Samsung updater thing will not let me update to Kitkat 4.4.4 or Lollipop 5.0.
    Any ideas? Am I half rooted or something? I don't mind unrooting my device, I'd like to avoid a factory reset but if it is the only way I understand.
    I cannot re-root w/ towel root because the kernel date changed from June 2, 2014 to July 22, 2014.
    03-28-2015 08:43 AM
  2. Golfdriver97's Avatar
    Rooting does stop the update process, so that isn't so unusual. The strange thing is, the sudden failure of root apps working. As for unrooting, you may have to reflash the stock ROM. I don't think a factory reset will work in this case. I found a thread on XDA on what to do, but since some of your root privileges have been revoked, I am not sure if this will work: [Q] How to remove Root/Towelroot? | AT&T Samsung Galaxy S 5 | XDA Forums
    03-28-2015 09:12 AM
  1. S6 Wireless Charging - Fast Charging or Normal Slooooow Charging?
    By felloffthetruck in forum Samsung Galaxy S6
    Last Post: 04-17-2015, 08:55 PM
  2. Can I get some help getting phone to turn on?
    Last Post: 03-29-2015, 02:31 AM
  3. Why won't my Verizon 4g LTE come on?
    Last Post: 03-29-2015, 02:30 AM
  4. Can I get some help getting my Samsung Galaxy S5 to turn on?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 03-28-2015, 08:26 AM
