1. SovietRob's Avatar
    So I followed a tutorial that showed how to flash it to make it able to do the boot animation and I did everything he did but when I restart it just skips over the boot animation completely here are some screenshots. I have tried putting them in the data/local as well but I still have the same results, I have also tried multiple different animations and still don't work. I tried on my old Ace 2X before I got this one and it didn't work on there either, I'd like to figure out what the problem is.
    Attached Thumbnails Samsung s5 changing boot animation problems-screenshot_2015-08-21-07-49-07.jpg   Samsung s5 changing boot animation problems-screenshot_2015-08-21-07-49-17.jpg
    08-21-2015 08:58 AM
  2. ironass's Avatar
    Hello and welcome to Android Central SovietRob!
    Have you got a link to the original installation instructions for that bootanimation as I would have thought that as a .zip file, that it would need to be flashed in recovery mode!
    08-21-2015 12:12 PM
  3. sidward35's Avatar
    Try installing the new boot animation using this app: https://play.google.com/store/apps/d...oot.animations
    When manually installing a boot animation doesn't work for me, I use this to install the animation and it works perfectly fine.
    08-21-2015 05:40 PM
  4. SovietRob's Avatar
    Doesn't work
    08-22-2015 07:37 PM
  5. SovietRob's Avatar
    Doesn't work
    Yea you flash it while in recovery mode.
    08-22-2015 07:41 PM
  6. ironass's Avatar
    Doesn't work
    Therefore, shouldn't the .zip file be on somewhere like the root of sdcard or extsdcard and not in, "system/media". The extracted and flashed file, in recovery mode, should be in, "system/media".
    Can you post a link to the original installation instructions?
    08-23-2015 02:41 AM
  7. SovietRob's Avatar
    I'm not allowed to post links but that is the animation, the flash zip is to be placed on the sdcard or extsdcard and you flash it and install it as a zip, which I did and then your supposed to place it in the system/media and give it a write perm of 644
    08-23-2015 11:27 AM
  1. Why is my S5 mini taking so long before finally ringing?
    By AC Question in forum Samsung Galaxy S5 Mini
    Last Post: 08-21-2015, 10:03 AM
  2. Replies: 1
    Last Post: 08-21-2015, 09:43 AM
  3. How can I tell if my Samsung Galaxy 4 Pro 10.1 is charging
    Last Post: 08-21-2015, 09:37 AM
  4. Is there a way to see a call forwarded from another phone?
    Last Post: 08-21-2015, 08:38 AM
  5. Replies: 1
    Last Post: 08-21-2015, 08:29 AM
