1. Noanme81's Avatar
    I accidental deleted everything on my phone using twrp. I was trying to delete the cache but deleted everything. I then power down my phone through twrp. My phone can no longer be turned on at all. I cant get it to go into down load mode or recovery mode. When I plug my phone into my computer it is recognized in device manager. Is there any way to get to download mode or twrp so I can reinstall the os on my phone
    Thanks
    Samasung s 5
    04-01-2016 10:19 PM
  2. B. Diddy's Avatar
    Moved to the S5 Rooting forum.
    04-02-2016 02:10 AM
  3. ironass's Avatar
    Which of the 42 models of Galaxy S5 do you have? See 42 Galaxy S5 models - Dummies Guide
    Were you on a custom ROM or stock Samsung firmware?
    Did you use the, "Format data", option in Advanced Wipe on TWRP?
    04-02-2016 06:15 AM
  4. Noanme81's Avatar
    I was able to install the stock ROM on my phone. It was working fine for the day but then the phone started to lag. After lagging for a bit the background on my phone went black. It was frozen so I had to take the battery out to shut it down. Now I cant get the phone to do anything. The way the phone froze makes me wonder if the phone is beyond repair.
    04-03-2016 12:39 AM
  5. ironass's Avatar
    Unless you can get the phone to turn on and enter either, Download or Recovery modes, there is nothing that can be done as the phone is, "bricked".
    04-03-2016 03:21 AM
  6. Noanme81's Avatar
    I was able to get the phone into down load. I installed it with stock ROM I found on another website
    04-04-2016 12:26 AM
  7. ironass's Avatar
    Glad you are up and running.
    04-04-2016 11:48 AM
  1. Replies: 3
    Last Post: 05-13-2017, 02:30 PM
  2. What's wrong with my phone's cameras?
    Last Post: 04-20-2016, 09:05 AM
  3. Droid RAZR M will not charge all the time
    By TechyVinnie13 in forum Droid RAZR M
    Last Post: 04-03-2016, 06:50 PM
  4. Need a new phone for my husband
    Last Post: 04-02-2016, 05:42 AM
  5. Replies: 1
    Last Post: 04-02-2016, 02:15 AM
