A
Android Central Question
The problem is that apps start to crash specially instagram and whatsapp in every 7.1.x rom i test. I already tried with different gapps and only genius 3.2 is working fine atm
Yes i've tried exactly these and more, the problem don't go away unless i try an 6.x rom. And i tried with every gapp in resurrection remix (the more stable rom as i see by comments). And of course i do factory data reset before and i do not do backups.First and foremost, ensure that you are using the correct custom ROM for your model of phone... the non 4G/LTE, G900H. Any other custom Galaxy S5 ROM will not be compatible with this phone. I would suggest... Resurrection Remix, Paranoid Android or Lineage. Also, remember to use the correct gapps package recommended by each developer, for your phone. All custom ROMs require that you do a Factory Data reset and a fresh install of apps, (no backups), when setting up. Check the developers thread for a particular custom ROM to see if others are experiencing similar problems.
