1. Maq Attaq's Avatar
    Hi all,
    I would like to root my Samsung Galaxy S5 Duos SM-G900FD ,but I don't have a PC at the moment!
    Please tell me how do I root it without PC!
    BTW,is there a way to enable root rights without rooting?Some app like 360 Root?
    Kingo Root?
    Thanks to all in advance!
    Best regards!
    05-10-2018 07:51 PM
  2. ironass's Avatar
    As far as I know, you cannot root the G900FD if you are on Android 6.0.1 without using a PC and Odin firmware I am afraid.
    05-10-2018 08:55 PM
  3. Maq Attaq's Avatar
    Dear ironass ,thank you for replying!
    Please tell me if the 360 Root application could help somehow?
    05-10-2018 08:59 PM
  4. Maq Attaq's Avatar
    I needed to root my phone in order to use one app which converts the MicroSD formats.
    If I cannot root my phone without PC, I would like to ask you to find for me an application for a non-rooted phone which could help me convert my MicroSD card format from FAT32 to ExFAt!
    Please help me dear ironass!I would be very grateful!
    05-10-2018 09:06 PM
  5. ironass's Avatar
    Just a few questions...
    1. What is the make of your microSD card?
    2. What size is your microSD card?
    3. What Android version are you running on your phone?
    4. Do you intend using files on the microSD card that are larger than 4GB?
    05-11-2018 09:25 AM
  6. Maq Attaq's Avatar
    1.I don't know who is the maker of my card,it is old and I can't read from its surface who is the maker.
    2.Its size is 8 GB, with 7.40 GB free space when formated.
    3.I am running at Android 6.0.1
    4.I would like to download a 7.22 GB file to it!
    Please help me!
    05-11-2018 09:33 AM
  7. ironass's Avatar
    I am afraid that you are out of luck Maq Attaq!
    If your microSD card is that old and small it will not be able to be formatted to EXFAT. Even if you could, the file headers, etc; in EXFAT are larger and would reduce the available space on the card to below that which you require not to mention that the card will probably not be, say, a Class 10 with fast read/write speeds. Typically, you should be looking at getting, say, a 32GB or higher, SanDisk Ultra 32GB microSDHC Memory Card which, if memory serves me correctly, usually come formatted to EXFAT.
    05-11-2018 12:46 PM
  8. Maq Attaq's Avatar
    Well I downloaded a smaller file and it is OK.
    Could you please tell me how do I make a bootable Win 10 USB via my phone?
    05-11-2018 12:49 PM
  9. ironass's Avatar
    Without a computer, you cannot.
    05-11-2018 03:58 PM
  1. how to remove animated toaster at top of contacts screen?
    By p5200 in forum Samsung Galaxy Note 8
    Last Post: 05-21-2018, 11:56 AM
  2. How can I root my device?
    Last Post: 05-11-2018, 10:26 AM
  3. why is my find my samsung 2 step verification asking for my old number
    Last Post: 05-10-2018, 07:41 PM
  4. My Droid only shows links in my Hotmail app. Is there a way to correct this?
    Last Post: 05-10-2018, 06:12 PM
