Hi
I'm a new android user. The problem I'm having is that when my wifi drops out or if I come home the Internet on my phone does not switch back from mobile data to wifi. I'm with bigpond and I have put the password into my phone and I don't need to put the password in each time but when I go to wifi settings it says sign in required and I press connect and the wifi turns on. As soon as I come home or the Internet drops out it switched back to 3G and doesn't connect back to wifi unless I do what I mentioned above.
The advanced setting on the wifi are
Proxy-none
Ip settings DHCP
Signal strength- very strong
Security wpa2 psk
I also have the smart network switch toggled to off. I have reset my telstra router.
I would love some help with this, I will readily admit to knowing nothing about android but I'm willing to learn. I've wasted a lot of my mobile data this week before I realised that when I left the house or the net dropped out my phone was staying on 3G and not switching back to wifi the way my iPhone and every other phone I've owned did.
Thanks so much
Proxy-none
Ip settings DHCP
Security wpa2 psk
Thanks so much
