Need help changing my alternate pass code! but forgot original one!
dking9101
Active member
Jul 13, 2010
36
I've been using the fingerprint scanner on the GS5 but sometimes I run into problems I tried to enter my alternate pass code (or at least what I thought it was) and it doesn't work, and in order for me to change it I need the original which I don't have. Is there any way to bypass this and create a new one?
Kilroy13
Banned
Jun 13, 2013
360
Go to the store and see if they can help! Of course they will verify if it's your phone or not first!
Sent from my HTCONE using Tapatalk
Stephen Clinton
I had the same problem. Delete your scanned fingerprints, this also deletes your alternative password. Then just rescan your fingers and reset the password :)
sirmaru
264
Google this address to replace a forgotten password: Android Device Manager. You must use your google password to access that site. Then you can lock your phone with a brand new phone password and use that one in the future.
mgalvez1029
Active member
Apr 30, 2014
25
Settings
Quick settings
Finger scanner
Finger print manager
(in this step, you will need to verify by scanning your finger print)
Select menu (in the upper right hand corner where the 3 dots are)
Choose Deselect
nmres
Scanned fingerprints can't be deleted if the phone can't recognize your print...still needs the alternative password...
AZgl1500
1,971
Clear out all Credential Certificates.
Settings (search for 'cre') select Clear Credentials.
Passwords and Pincodes will be erased.
Not sure about the Fingerprints, but those should go also.
Debbie risley
Go to:
Settings
Fingerprint Scanner
Fingerprint Manager
Swipe down your Index finger (dont forget that's the finger you used to set it up with) I kept using my thumb
swipe it straight down the middle
Press and Hold Fingerprint 1 and you should see the trashcan icon, once you delete it you will need to re configure your fingerprint, but it will walk you through it, and then pick your password, it has to be at least 4 characters and have a letter in it, not just numbers keep it in mind when you re do it so you don't have to go through this all over again!!!
This worked for me on my Galaxy S5 for Sprint phone. Good Luck!! :)
samyblaze
