Hi All,
I'm having a problem with my S5, the caller's voice coming out of the earpiece is very bad in quality: I get a distorted sound and some sound vibration in my ear just like a blown speaker. I'm sure it's not from the carrier as it happens on Viber calls on Wi-Fi as well.
Is there any way I can adjust the sound? An equalizer app or the like?
Does Adapt Sound work on the earpiece for voice calls and Viber calls?
I don't want to send the phone to be repaired under warranty as it will take a long time, so any input is appreciated.
Thank you kindly.
Thank you kindly.
