I've had a fun afternoon with Virgin Mobile... I received a new Samsung S5 4 days ago and hadn't noticed until now that incoming calls weren't getting through, when I tried calling my mobile from a different number it was saying that the phone wasn't connected.
Fix - re-seat the sim card - Worked for about 2 minutes and was successfully receiving incoming calls, then I noticed that every call I made to the mobile went to the answer machine so called Virgin mobile back.
Fix - Go into settings and remove reference to LTE as follows (I am on a 3G contract)
. Settings
. More networds
. Mobile networks
. Network mode
. Select WCDMA/GSM (auto connect) – The default is 'LTE/WCDMA/GSM' and as I don't have LTE was told to switch this off
This fix worked for another 2 minutes, and then I noticed that every incoming call went to the answer machine, so I called back...
Fix - Turn off wifi
Incoming calls work fine now, and every time I turn on wifi they go to answer machine.
I then did some searching around the net and also called Samsung UK directly, and was advised that I have a faulty handset and to ask Virgin Mobile to replace it.
I then called back Virgin Mobile and was told that it affect Kit Kat and ALL networks, and Samsung are aware of the issue. I was told that they wouldn't swap it for another Samsung S5, but as I am only 4 days into my contract they can swap it for another make/ model.
Anyone else noticed this, it appears to be a little intermittent, but I can reproduce the issue fairly consistently when turning the wifi (in the settings) on and off
. Settings
. More networds
. Mobile networks
. Network mode
Fix - Turn off wifi
